What's in the mailbox? 📬 📦
Thanks finebyfine. Looks like I'd need to pick up an MC1496 as well to mess with that.
Unfortunately, even if I breadboard the Appnote AGC circuit and mess with it, I'd be doing just that — messing with it.
My understanding and knowledge isn't quite at that pay-grade yet. Maybe yourself, Robert or Dave might know how to pull some audio through that combo, but I'd be doing it by blind trial and error.
I did think that maybe the 592 could maybe used as a straight-ahead op-amp somehow.
@Feral Feline idk too much about any of those chips, but it seems like some of them are for video applications— might be able to do some cool critter & git TARI style videobending circuits with some of them, though I wouldn’t even know where to begin.
One of my guitar cables that I’ve had for 12 plus years just died last night. What cables do you use?
These are XLR to TRS balanced cables from monoprice. I use some of their instrument cables and they're fine. I mostly use monster cables that I bought 20 years ago when they had a no questions asked replacement policy but I wouldn't buy them today
Further to my EG order (post#2213),
I’ve sorted a free grab bag of LEDs (mostly yellow, a few red and a smattering of white and one blue) and
sorted two boxes ($5/ea, 50% off) of “grab-bag” ICs:
Multiples of two or more are down flat, random singles are leaned against the PCB-holder at the back.
SKIP the following indented list, unless you want to be bored reading my redundant entries...
I've got​
- 4x 555-timer ICs — the only thing I found immediately recognisable. Hardly worth the investment just yet.​
- A baker's dozen of BL1240 — turns out to be "a monolithic integrated circuit designed to replace mechanical bell in telephone sets in connection with an electro-acoustical converter. It can drive directly a piezoceramic converter (buzzer) or a dynamic loudspeaker." So maybe there's a noise-maker project that can use one of these.​
- 3x NE592N8 — "a monolithic, two-stage, differential output, wideband video amplifier." Gamble has yet to pay off.​
- 2x SN74163N — "Synchronous 4-bit binary counter" ...​
- 5x DM7446AN — These ICs "feature active-LOW outputs designed for driving common-anode LEDs or incandescent indicators directly."​
- 2x CD4093BE — A four Schmitt-trigger circuit. Finally something useful, for an Atari Punk Console or Parasit noise-maker etc.​
- 2x DM7425N — "Dual 4-Input NOR Gate (with Strobe)"​
- 8x SN7486N — Logic => Gates => XOR (Exclusive OR) Gates​
- 6x SN74148N — Encode 8 Data Lines to 3-Line Binary(Octal)DApplications Include:− n-Bit Encoding− Code Converters and Generators​
- 4x CD4503BCN — CMOS HEX Buffer, 3 state non-inverting type, high voltage (20v). Can't think of any use, already had 3 in my IC stash.​
- 6x DM7473N — Dual Master-Slave J-K Flip-Flops, with Clear and Complementary Outputs​
- 5x SN7425N — "Dual 4-Input NOR Gate (with Strobe)", just like the DM7425N in the first group above.​
- 10x 74157PC — Multiplexer, 4-Func, 2 Line Input, TTL, PDIP16​
- 4x DM7446AN — different batch-code from the first group's 5 of this IC for driving LEDs. Yawn.​
- 4x SN74LS375N — D-Type Transparent Latch 4 Channel 1:1 IC Differential 16-PDIP​
- 3x T74LS158B1 — Quad 2-input Multiplexer (inverting)​
- 4x SN74LS155AN — Monolithic Transistor-Transistor-Logic (TTL) dual 1-line to 4-line demultiplexer​
- 4x SN74LS375N — 4-bit bistable latch​
- 3x DM74LS160N — Synchronous Presettable BCD Decade Counter​
- 3x SN74F258N — Quadruple 2-line to 1-line data selector/multiplexer, with 3-state outputs​
The back row:​
- DM7473 — batch code different from above, should've chucked it in with group 2's batch of this IC.​
- DM7425N — yet another multiplexer to add to the first group.​
- DG412DJ — monolithic quad analog switches was designed to provide high speed, low error switching of precision analog signals.​
- N7486A — Quadruple 2-input exclusive-or gates​
- DM7473N — Guess I should look at part #s rather than batch #s — another one to add to the 2nd group above​
- SN7486N — It's a Quadruple 2-input exclusive-or gates, just like the 2nd entry above.​
- SN7486N — different manufacturer from the ones above.​
- 74148N — another to add to the ICs of its kind in the 2nd group above.​
- SN7473N — I really must sort by the IC codes and not the batch codes next time.​
- SN7486N — Ditto.​
I searched my hard-drive with every chip code above in the list, to see if I got a hit for any of them in my cache of build-docs.
Anybody got any hacks for the BL1240 or NE592 chips? Those are the only ones that I can see maybe using them for purposes they weren't designed for, even if they didn't come up in any build docs.
The only hits worthwhile were the 555 and 4093.
So the 555 is 13¢ at Tayda (subtotal $0.52), and
the 4093 is 83¢/ea at mouser (subtotal $1.64) OR 40¢ ea at Tayda so let's go with Tayda ($0.80 subtotal)
All I got was $1.32 of useful-to-me chips, didn't even break even.
I gambled $10 on ICs and lost. 🤷‍♂️ Glad it wasn't $20.
Been there! I have a box of grab bag “goodies” I bought off eBay for a lot more $ than I should have. Some useful mojo parts that need a bit of love (some light sanding of leads, etc …), a bag of the dimmest friggin’ 3mm red LEDs I’ve ever seen, a handful of super weird ICs … and one, ONE usable PNP Ge transistor with no markings. 😂 I’m a sucker for a deal.
Speaking of which, I did snag a grab bag from LMS when they moved shop and it was epic - several sets of b stock knobs (I use for my own builds), couple of pots, a Gorva s90 in military green with a scratch somewhere I still can’t find, and other goodies like a right angle 1/4 inch trs plug.
I guess some days you get the bear and some days the bear gets you.
Some PCBs courtesy of @finebyfine -
  1. Optofet Comp
  2. Octave Up Sick Box
  3. Clean Octave Blend
  4. Ringer redux w/ Null
  5. Super Full Wave Octaver
Quality seems ace, and they're drop in compatible with PedalPCB, which I think is pretty nifty
Really looking forward to the octave builds. And, hadn't crossed my mind, but perhaps I can Spluff em
Been there! I have a box of grab bag “goodies” I bought off eBay for a lot more $ than I should have. ... 😂 I’m a sucker for a deal.
Speaking of which, I did snag a grab bag from LMS when they moved shop and it was epic ...
I'm a sucker for deals, too, but I missed out on the LMS moving extravaganza COMPLETELY.
Just wasn't aware of it.
I can't bear it.
Nice. I’m about to unload my HOG 2, the Meris Enzo slays it.
I think my buying spree is over for now.
Nice. Haven't tried the Enzo yet, though I think it definitely serves a different synthesis role than the HOG. The Enzo seems more geared towards getting Carpenter-esque and synthwave type sounds (which is rad), whereas the HOG is basically a Drawbar organ with a few FX thrown in.
The thing that's kept me from getting the Enzo are the alt modes and lack of visual feedback in regard to where the parameters are set. Also, it's goldenrod, and I hate yellows :ROFLMAO: From what I've seen in videos I'd probably love it. I think the thing that would make me buy one is if the portamento can do do the theremin thing
I will report back when I finally dive into it enough. Once I find a spare week. 😂
From the vids I've watched, it's portamento seems closer to the HOG and SuperEgo's gliss, but maybe a bit more like the one found on the Synth9. It's a great sound, but not quite the portamento I'd want.
For reference, this is the kinda pitch glide I'm looking for -
The Theremin Fuzz / Sim do it well, but it lacks any degree of polyphony
