Bottom = Rat = variable low pass filter
Middle = Muff = a low pass filter and a high pass filter combined
Top = variable high pass filter
Basically a Muff tone control is a low-pass filter and a high-pass filter combined, so in the cleric the two filters are individually hooked to the on/on/on switch. It turns them both on in the middle, then only one or the other in the other two positions (a genuinely cool trick from JPTRFX that I haven’t seen elsewhere but would love to be better informed if I’m incorrect)
I love the high pass filter on the OG pedal (go-to mode of the three), it lets you tighten the bass and/or get *super* sharp and aggressive
So cool. Thank you.
I've never seen an SPDT on/on/on switch TBH so I doubt it's that. Genuinely curious about the schematic bit of this, let's see how "soon" build docs will be available....
EDIT: Also, apparently it's top position muff, middle position muff with more mids, bottom position rat.
I suppose it's entirely possible the youtubers are correct with regard to the particular unit they're demoing / describing.
The product description for these seem to be all over the place with very little to distinguish between the variations.
Is it standard KLON order?
Gain
Treble
Level
Also is this going to be a limited run of a certain number of boards? If so how many?
That's correct, Gain / Treble / Level from left to right looking at the knobs.
There's no plan to discontinue at any time soon.
