Is there a BoM cheat sheet for the Bobby?
could just follow the little green scream machine docs and then use this schematic as your 'true' reference:Are the Mean Green Metal Machine build docs available yet?
Cheers!
Is there a schematic for the protoboard?
Thanks for the Victory preamps. Is it planned to release the flock schematic?Any info about the flock schematic and all the Victory style preamps?
Any build docs for Decadence Preamp? I was able to find a txt file with BOM, but not sure how to populate the board other than comparing to image of complete board found online
I’m coming to learn it’s so much easier with the values on the board.Yes of course, the schematic will be in the doc when it's posted.
The component values are printed directly on the PCB.
I'm working through some build docs now but there are a few others ahead of this one.
That is not a picture of the board you will get in the mail. The actual boards have values on the silkscreen.View attachment 41612
I might be too new at this, but the board looks like the only values printed on it are for the pots. Seems like the markings are similar to what I got on the El Sol, where they related to a position and the build doc linked the position to the component. I guess the schematic would have both? Sorry for the confusion, I'm sure this is a me issue
Bumping this. I could use the bom/build docs and drill template too if it’s available.Can I get equilux equalizer schematics?
I'd still love the schem/ build docs, but I'm 99% sure it's my CD4013s that are bad. I just built another Octarock and a Pearl OC07 clone, and both exhibit the same behaviours for the lower octaves.Still needing the schem for this one.
The upper octave and direct signal work, but I'm having an issue with the Sub-Octave. When first powered up, it runs fine, but quickly dies out in a few seconds, and just becomes ridiculously quiet
You know that is the Mad Professor Grey Stone Distortion, right?
