Chuck D. Bones
Circuit Wizard
I've found a simple circuit mod that gets rid of the LFO tick in the EQD Sea Machine (Sea Horse) and Space Spiral (Dark Rift).  It has been tested on both pedals.  It's the same mod for both pedals, only the ref designators are different.
Sea Machine:
Remove C19.
Connect a 10nF cap between pins 1 and 2 on IC4. A small MLCC on the back side is a clean way to do it.
Space Spiral:
Remove C30.
Connect a 10nF cap between pins 6 and 7 on IC5. A small MLCC on the back side is a clean way to do it.
In theory, a mod of this sort should also work on the Chaos Machine & BiPhase. It requires more surgery on those two pedals and has not been tested (yet).
			Sea Machine:
Remove C19.
Space Spiral:
Remove C30.
