eh là bas ma
I noticed that this statement is raising a few interesting points :Contrary to popular belief, a lot can be used on bass with no problem. I don’t gig anymore but I did for years. The only real issues I’ve found is with dirt, which most can be modified.
"A lot can be used on Bass with no problem" : No problem, like no major bass cut, no calibration on the wrong frequencies ?
Many guitar effects are partially working on bass. Is "partially working" good enough ?
Even with modulations, playing bass with a CE-2 or a CE-2b, you will hear the difference. A CE-2 is ok, as long as you didn't try a CE-2b, then you can feel the CE-2 isn't working as well as a CE-2b, and CE-2 isn't good enough anymore.
If the situation was reversed, and guitarists were in dire need of effects calibrated for their needs, if they could only find mostly bass effects and, years later, got used to it, wouldn't they feel like there are "no problem" ?
"most can be modified" : So that's it ? bass players just have to entirely reshape guitar circuits forever, because any circuit can be modified ?
Why not sell pre-modified pcb then, if it could save some time to many people ?
Wouldn't you be a bit frustrated as a guitar player, if you could only modify some effects calibrated for other instruments ? Playing an ODB-3 with the tone all cranked up, would it be perfectly ok, just as good as having an OD-3 ? Take it or mod it ?
Let's be reasonable...
Edit : Here is a mod exemple, converting a Klon for Bass :
So that's how it looks. I mean who can do that ? You have to be a circuit wizard, or electronic engineer to come up with this kind of modifications for every circuits. "most can be modified" sure, but you have to be quite knowledgeable ?
