That threw me off initially as well, but according to a couple other builders (Breakfast Audio, Niche Devices), TL072 (dual op amp) runs on +17V/-17V, meaning ground, or better stated, “0V,” is half the op amp supply. If you think about the power supply as potential and absolute numbers, it makes sense.
R5 is biasing the op amp. I’ve seen
synths and studio equipment schematics that employ the same stuff as well. I also suspect R7 plays some sort of role as well but I am not sure and basing this purely on the Eunuch where R7 is connected to the bias voltage.
Furthermore, if you look at the Eunuch Buffer (
https://www.pedalpcb.com/product/pcb581/), which is the Skeptical Buffer minus the elaborate bipolar voltage supply and runs on 9V/0V, R100 and R101 forms a voltage divider, equaling half the op amp power supply or 4.5V. (Eunuch can run at higher voltages, but 9V is the ‘starting’ voltage.)
I postulate that if you want the Eunuch to match the headroom of the Skeptical Buffer, you may need to run the Eunuch at 35V.
EDIT:
I have also attached a picture for what I believe is the Eunuch Buffer schematic so that you may try that in LTSpice or any other simulator. I pieced it together based purely on speculation and looking at the picture of the PCB on the product page.
Note:
- Pin 8 and 4 of IC1 are now attached to +V and ground (or 9V and 0V, respectively)
- The addition of the voltage divider network (R100, R101) and C11. The part values are numbers I pulled out of thin air, but as long as R100 and R101 are equal, the circuit should theoretically work.
- R5 and R7 are now attached to Vref (VEE, 4.5v).
