Looks like any 4-knob Type 1 drill template will workHi there!
Any drilling template for Virgil?
Is the full size Equinox drill template available anywhere? I've searched the threads and can't find it.
Thanks!
@manfesto to clarify, with the Powder Blue drill template , pots and switch are at the same place? Because led is way lower in front of footswitch.Precipice looks like the standard 3-knob type 1, Poison Apple looks like the standard 4-knob type 1
The Scenario you can use the same drill template as the Powder Blue (4-knob layout but you drill the center LED hole bigger for the center switch)
LED placement is the same as well (same place it is on the 6-knob layouts too, above the footswitch)@manfesto to clarify, with the Powder Blue drill template , pots and switch are at the same place? Because led is way lower in front of footswitch.
as a technology guy I refuse to read manuals, figure it out on my own, and then don’t write down anything so the next time I (or god forbid a coworker) need to do it I gotta do it all over again.as a technology guy I have to state that user docs should be an integral part of any company's product release process...
1. Looks like, yepSome drill template questions:
1.) Snozzberry Overdrive is just the standard 4 knob enclosure, right?
2.) Desolate fuzz would fit in a standard 5 knob enclosure? Or should I take the 5 knob template and change the hole sizes so they're a bit smaller for the switches? I think the switches should still work in pot sized holes though.
3.) Aberration fuzz looks like the standard 3 knob enclosure, I'm quite sure about this one.
4.) Viceroy overdrive is the standard 6 knob enclosure, but just with twice the footswitches and LEDs?
Ah, the mortal enemy of the tech comms dept.as a technology guy I refuse to read manuals, figure it out on my own, and then don’t write down anything so the next time I (or god forbid a coworker) need to do it I gotta do it all over again.
Need a drill template? Looks from the tags on the pedalpcb website like you could pick a drill template from any of these to guide you: https://www.pedalpcb.com/product-tag/3-knob-type-1/It would be very helpful to have the build docs for the Crystal Drive, since I now have the PCB in hand. I like your PCBs very much, but as a technology guy I have to state that user docs should be an integral part of any company's product release process...
