Relative Noob here. I've completed a few projects with success and trying to improve as I go. Below are few nagging questions that I can't seem to get a clear answers from searching this forum or general web search. Feel free to link to another thread, maybe I'm using the wrong keywords. Thanks in advance.
Why is it necessary to clean all solder flux from PCB's? Here is what I've gathered so far:
Why use Tantalum capacitors? I've never used them, but I see they are quite common on various build reports. I've generally used ceramics for pF, film for nF, and electrolytic for uF and have a decent stockpile of each.
- Looks better. I agree with this, but for most projects I don't care.
- Helps check for solder bridges. I agree with this, but I'm confident I can check for bridges with limited cleaning, magnification, and a bright light.
- Long term corrosion. I've been using SRA Rosin Paste Flux #135. This product claims it does not need to be cleaned and "the rosin also leaves a protective coating over the soldered area that can prevent corrosion." This stuff is likely more messy than a flux pen, but I've had good results so far.
- Why are tantalum caps better? How much difference do they really make?
- Seems like the general recommendation is to use them in the signal chain. Are there any advantages to use them in other locations?
