Fuzz Wizard
I’ve ran into a lot of trouble with this build. First of all, when I drilled the encloser the jacks were too far down, and I couldn’t fit them in. So I went back and drilled a little bit higher as you can see in the picture, but I’m afraid that it might not connect to ground. Second of all, I wired the footswitch backwards at first and had to re-wire it, so there was a lot of desoldering going on there. Now when I plug the pedal in, I only get bypass when the power is not connected. Once I plug in the power, bypass stops working and there’s no sound, however the LED still turns on. Any help would be greatly appreciated, this is really one of my dream pedals that I wanted to build when I first started.
