FYI... I just got a note from Hugo. He's now having the same issue on the drill tool with Chrome... so hopefully his IT will be able to get it fixed...
Chrome has been fucking things up across the internet for me for months. Drill tool sometimes doesn't work for me on Chrome but always works on Firefox - I should finish my permanent migration there...
I usually drill my own enclosures but for various reasons decided to give Tayda's drilling option a try. I ordered some clear matt finished 1590Bs with a simple drill pattern with top-mounted jacks and it turned out really well and they arrived in good time - maybe two weeks? I think that because I ordered the jack holes slightly over-sized assembly is a breeze. And having the finish over the holes makes everything look very smart.
I use chrome and everything went smoothly. I'm really impressed. I get a drilled and finished enclosure and it's still cheaper than I can buy just a bare box here!
You can always try removing cookies to see if it fixes issues with websites. Or try the incognito/private mode which does the same trick, essentially. It helps surprisingly often.
In practice incognito would just reset cookies for that incognito session (and not save anything), so chances are it wouldn't change things. But might as well try. It might also disable some addons depending on how they are configured, so that could also help with some issues.
