What’s on *YOUR* workbench?
So I did some experimenting today. I decided to mix 2 different top coats together.
Here are the results:
It’s a purple that color shifts to gold with the rainbow effect added lightly to not disturb the true color. I think it came out fantastic!
The colors much much more intense in the light. It was hard to capture shots of everything going on at once.
WTF I've just seen this. My two favourite colours in one place. Like @Feral Feline can I add an enclosure in this colour to my order too please?
You could just turn your 125b's with top mounted jacks on their side & transfer the Pots & footswitch with led there as well, now there is some space saving!!! ;)
1Ur_fYQRKkX55z2BdspAkD9nEgoHj3oJO561MgZUZ8mKXs13nuNP0mC0zqXFJyrKX2Yx5FXtPxSLb_H1_pzbtNb5XiFLomc_E5y0pAgNcQqmxP-IkQ
I have the PCB and a Pre-drilled enclosure. I thought of drilling another hole by the jacks so that at least it's only two sides that are occupied.
Either that or drill another hole on the south wall and stick the stomp-switch there, making it a kick-switch — will need the insanely strong mushroom-headed pedalboard tape for that config.
Actually, I recently found the decor for my Bear Boost Plus to help hide the stupid sides configuration.
Oh man, it feels good to find a clear culprit. I was troubleshooting the bypass signal being bad so I whipped out a tone generator plugin and a frequency analyzer plugin to figure out what was happening. I knew I was losing a couple of dB (3dB more or less), but I didn't realize this was also happening without the frequency analyzer:
I then started figuring out where it was happening, and it was happening right at the input to a lesser extent, and definitely before the JFET.
Buuuut then I noticed one of the diodes before the JFET was the wrong way around so just a good check for errors would have also cleared this up. So not an issue with the JFET at all.
Culprit:
