More stereo insanity.
Death Cap will be dual concentric (with a 10k pot modded to a non-existing 1K with two resistors in series), like my Supersonic Fuzz Gun. Viceroy dual gang, just like my Mofeta (fun stuff to put before my Mooer stereo cab IR loader, full of Sunn goodies) . Arkaim is going to be dual gang too, because of the C1M input pot. Will get a dry blend circuit addition as well (2 JMK PCBs Panner things).
Curious, if the dipswitch of the updated Megalith can be implemented by hand at some point? Per the manual:
DIPSWITCHES
1. Engages a clipping diode. Increases distortion and compression. Precedes the
tone control section. Effects the negative going part of the waveform. NOTE: Stock
DIP switch setting when in the ON position.
2. Engages a positive going clipping diode which compresses the distortion even
more than DIP switch 1 and effects the frequency content.
3. Boosts low end and signal strength going into the clipping diode section.Very
interactive with DIP 1 and DIP 2.
4. Boosts the mid range within the tone stack.
