It's not a drawing, necessarily, but I've been trying out doing some decoupage on pedals and this is my most recent attempt. Gonna put something gross and nasty in here since it looks gross and nasty.
I think it should be fine. My drill marks on dark enclosures are always 0.1mm crosshairs in the white layer. Meanwhile I’ve had design elements as close as 0.2mm away from each other and they didn’t bleed into each other at all. I’ve done the power symbol provably even smaller than that with no problem either. I would definitely recommend the double white option though bc I find the white to be a bit lackluster on a darker enclosure (Especially if this happens to be a sand black enclosure) without the double-white upchargeWorking on a couple that I plan to have Tayda print for me. I've had them do several so far, but none with fine detail. Does anyone have experience having them print fine detail on the white layer? Does it track well, and what line thickness/spacing did you have? Here's the design I have concerns about:
I'm most concerned with the power polarity symbol and the embellishment around the LED. I've had a few designs where things have kind of run together when there's not enough space. I'm hoping that someone else has done some fine detail stuff with them on the white layer and had good results.
Thanks!
Looks like what Cthulhu would stomp on.It's not a drawing, necessarily, but I've been trying out doing some decoupage on pedals and this is my most recent attempt. Gonna put something gross and nasty in here since it looks gross and nasty.
Redbubble it?I thought about getting stickers made of this but it wasn't worth the $20 or wherever cuz I'm broke so you can just roll your eyes at it here instead
It'd be cool if the outskirts logo glowed like @szukalski did with his sheepI have a feeling this isn't gonna print right so I'm probably not gonna use it
That would indeed be cool but I'm A. Anti faceplate and B. Not interested in that much effortIt'd be cool if the outskirts logo glowed like @szukalski did with his sheep
Simon Says?Anyone wanna guess?
A Winnebago? A baby's arm holding an apple?Anyone wanna guess?
