steviejr92
Authorized Vendor
Im soo gonna do a board for this! I love the demos and i have tons of PNPs that i havent used yet. I like that its a negative ground circuit using PNPs! Thank you for bringing this to the forums attention!Found nothing on this forum about the Tortenmann TA-100 germanium overdrive so wanted to share this great circuit! Breadboarded it this week and it’s going to be my next build now. It thickens up my Boogie Mark V90 3rd channel into Rectifier territory! But also has really nice lower gain drive sounds on tap if that’s your thing.
Uses 3 PNP germanium transistors in a negative ground format. Sounds excellent, good amount of crunchy gain on tap and adds nice girth to already overdriven channels.
Tested some different diode combinations (not extensively yet, just what was on my little diode DIP switch board) and my favorite was asymmetric clipping with MOSFET (2N7000) + Ge (1N34) on one side and 1N4148 on the other.
Used Toshiba 2SA478 with hfe in the 70-100 range with low leakage <120. But also didn’t mess around with leakage very much.
Give this one a go if you have some spare PNP Germs!
Some sound demos below:
1. Clean channel: bypassed then engaged with 75% gain
2. Dirty channel: bypassed then engaged, adds girth to the chugs
