[...]But what’s good for audio path, not good for audio path, etc. I’ve got ceramic, film, electrolytic, tantalum, mlcc…
Best for audio path:
up to about 47nF:
C0G ceramic, or film (film caps tend to be larger, pricier and easier to damage while soldering).
from 47nF to maybe 4.7uF: film
above that: electrolytic
I wouldn't use tantalum for audio (or anything, really). When they go bad, they tend to burn a hole in your PCB like a mini-thermite.
MLCCs using X5R or X7R dielectric can be ok for non-critical audio path use (such as guitar effects),
if you know what you're doing. Their capacitance can vary a lot with the DC bias across, and also with temperature. Best used for DC filtering, switching power supplies and the like. If you do have to use them with audio (I do), make sure the voltage across them (DC
 or AC) is much lower than their rated voltage, to avoid distortion and loss of capacitance. They can also be microphonic, so be careful in high gain circuits or you might get squealing/oscillations.
MLCCs using Z5U and Y5V dielectrics: just say no! They're terrible.
