Hey,
I just built a Paragon (side one standard, side two high gain) out of a kit I ordered from dasmusikding.de which works fine and sounds great. When I dial in very (!) high volume, tone and gain settings and engage both sides together it starts making loud squealing/whistling noises which change a bit when turning the knobs. If I dial back the tone knobs to zero it stops. This is without a Guitar plugged in.
When I plug in a Guitar in and leave its volume on zero it doesn't make noises even with everything on full. (!?) A soon as I start to turn the volume on the Guitar it starts making noises again. It stops while playing notes.
If I use the pedal with more "normal" settings, there's no problem at all.
I've checked the solder joints and the wiring several times. I interchanged the 4580 ICs. I tried a battery instead of a power supply. I varied the location of the pedal in the room. I tried it with the housing closed and opened. Before I soldered them in, I measured every resistor. I knocked on the parts with a wooden pencil and checked if they're all tight on the board. Nothing changed.
Is this behaviour normal? If not, what could it be? I've read in another thread, that sometimes a charge pump can cause noises. Could this be the problem? Why does it stop, when a Guitar with volume on zero is plugged in. Impedance on the input?
Greetings
Michael
Greetings
Michael
