Acrylic drive.
BishUncool
Can anyone show me a populated board? I'm not sure I did it right.. not sure if I have the right stuff in there. This is my first solo build.
Thank in advance 🤘
What capacitor values are those? I am not aware of ceramics in the uF range and those look tiny.
The 2 x 2n2, 10n and 22n caps is what he is referring to. They might be the wrong value as they don’t make smaller ceramic caps in those values generally (could be wrong). Double check em! Also where do you get your j201?
This is my first solo build. And I thought I didn't have the right caps. But I had these little ones from some box of caps, tans, and LEDs from Amazon. Thank you for showing me what works.
Did you use the correct values for the caps? What values are the ones in the build?
Might not be able to see, but I tried to get all the pieces right. Like I said l, I got those pieces from an Amazon set. To me they were right, but obviously not. Thank you for the help.
