You're very welcome. From what I can see, it looks pretty tidy and you've double-checked component values already. Try searching the forum for any additional info on these pedals. There may be some troubleshooting ideas right here. I had some issues with the Caesar IIRC. Let me see what I can find.thank you for the reply! I did try to press all IC, transistor etc but It didn't do much. What I find odd is that I have the similar issue in both pedal.
| Yours | Mine | |
| IC1 (TL022) | (TL062 subbed) | |
| Pin 1: 0.65 - 7.86 | Varies | 0.764 - 5.685 |
| Pin 2: 4.08 - 4.47 | 4.3 | 3.99 - 4.12 |
| Pin 3: 1.46 - 6.59 | Varies | Varies |
| Pin 4: 0 | 0 | 0 |
| Pin 5: 4.05 - 4.45 | 4.3 | 3.96 - 4.17 |
| Pin 6: 4.57 | 4.3 | 3.96 - 4.17 |
| Pin 7: 1 - 6 | Varies | Varies |
| Pin 8: 8.52 | 8.5 | 8.12 |
| IC2 (RC4558) | ||
| Pin 1: 8.73 | 6 | 3.88 |
| Pin 2: 8.69 | 6 | 3.89 |
| Pin 3: 8.74 | 6 | 3.89 |
| Pin 4: 0 | 0 | 0 |
| Pin 5: 8.75 | 6 | 3.89 |
| Pin 6: 8.74 | 6 | 3.89 |
| Pin 7: 8.70 | 6 | 3.89 |
| Pin 8: 8.75 | 8.8 | 8.23 |
| IC3 (V3207D) | ||
| Pin 1: 0 | 0 | 0 |
| Pin 2: 3.89 | 4 | 3.89 |
| Pin 3: 7.77 | 5.2 | 3.12 |
| Pin 4: 7.95 | 8 | 7.58 |
| Pin 5: 8.53 | 8.6 | 8.15 |
| Pin 6: 3.79 | 3.9 | 3.88 |
| Pin 7: 7.90 | 6.5 | 3.65 |
| Pin 8: 7.89 | 6.5 | 3.65 |
| IC4 (V3102D) | ||
| Pin 1: 8.53 | 8.6 | 8.15 |
| Pin 2: 3.79 | 3.9 | 3.88 |
| Pin 3: 0 | 0 | 0 |
| Pin 4: 3.89 | 4 | 3.92 |
| Pin 5: 0.80 | 0.8 | 0.390 |
| Pin 6: 7.54 | 7.6 | 7.59 |
| Pin 7: 2.64 | 2.9 | 2.34 |
| Pin 8: 7.95 | 8 | 7.57 |
I used coolaudio BBDs from Stompbox parts in a Caesar and three low tide builds recently and they all worked fine.Those Coolaudio are not too good.
If you recall @Robert’s post above, I don’t think it’s the BBDs (at least in the Caesar build). The problem seems to lie with the oscillator part of the circuit. Maybe see if you are getting any pulses in that part of the circuit before replacing the BBDs.Thanx for the IC voltages. I tried changing the opamp on both pedals and still nothing. I ordered some cheap NOS BBD from china. I'll try swapping them before digging any deeper. I once had a defective Maestro chorus pedal with a bad BBD and the sound was pretty much the same as what is happening right now. Those Coolaudio are not too good.
I’d start with the pins with varying voltage on IC1, which is the oscillator chip. You do have an 022 there, right? Do you have a multimeter?When did you buy them? https://www.freestompboxes.org/viewtopic.php?p=302125. This was my exact experience with this (great) pedal. The UC200 from Behringer also have this common issue were they just stop working. Behringer own Coolaudio. Maybe they had a bad batch or something... I could also be wrong, it's just based on my experience with this chip. Glad that some have success with it
I'm not a schematic expert, any specific part to look at on the PCB? It's easier to swap IC and transistor before unsoldering stuff maybe i'm putting all my hope on the BBD for that![]()
Yes, that looks right. Check pins 1 and 7 for good measure.hey thanx a lot for the visual cues on the schematic. I'll test that later and post the result. It's a good idea to focus on one pedal. I'll test pin 1 on the tl022. Is this the correct pinout? mines are TL022CP
I think take board ground as your reference and if so, pins 1 and 7 should vary in accordance with the rate pot.I'm not so sure how to measure an IC do i use pin 4 for ground or the boards ground or it doesn't mather since it's the same ground?
TL022:
Pin 1 with 4 i get 8.26V
Pin 1 with ground i get 8.26V
Pin 7 with 4 .718V
Pin 7 ground I get .718V
