Thank you robert
Yep It is phase inverter. So thats to use in a two amp set up or for a 2 channel amp, or amp and direct. I have a barber launchpad that I used to the normal channel and treble boost channel of my ac30 with an inverted signal.
But while typing I guess its to use in some setup with a compressor.
Trs in and out with inverted going to TS. Basically using as a buffered split and not worried about inverted signal as it's for sidechaining a comp.
Saved me a good bit of change.
Let's talk about the importance of having an EQ pedal... Or 5...
The whole bunch is plugged into loop switchers, and midi controlled. And your live was in danger, before you made a splitter to sidechain a compressor.
I think all my questions are answered
Hyperbole I know, but it saved me space by being able to place the clean on top of the other enclosure and keep my cables how I need for other drawers Finding a third party buffered split in the configuration and enclosure size I need was driving me nuts until I saw this board.
