You mean a mute switch or a power switch? My preamp boards all have some form of mute with an LED to indicate if on or off. A power switch can be added in series with the incoming power from the jack and an LED, with resistor, on the other side of the switch.How can I add an on/off power switch with indicator led.... to the tpa3118 board? I apologize
Awesome build!Hello all! Dropping into to thank you all (special thanks to @Willybomb and @Paul.Ruby) for all the helpful information and contribute my recent build.
My main tube-based rig is a Helix (as a pedalboard) -> Bad Cat Cub 15R head -> Matchless ESS112 (H75 Creamback-equipped). When impractical to haul the amp head, I use Matchless (and some Marshall) amp models (without IR) and the power section of a Quilter Superblock US to power the Matchless cabinet with great results. When I do run direct, the IRs I use are remarkably similar to my cabinet (York Audio Matchless IRs). From what I read on here and The Gear Page, the 3118 amps looked like a great option as a leave-in power amp for the cabinet and I couldn't be happier so far.
Notes and observations:
1) With my Helix's output set to Line Level, there is PLENTY of volume on tap. It is louder than the Quilter Superblock at full voltage/volume and sounds just as good. Anyone reporting lower-than-expected volume is using the wrong input signal (level, impedance, or both), imposter 3118 board or error in their construction. I ordered mine from this seller and both boards are legit 32-pin boards.
2) I used the schematic posted earlier in this thread. I added a power switch and LED but omitted the 200nF input DC filter cap. 50K Log taper volume pot is just right. I am using a 35V 4700uF capacitor to let me safely use a 24V 3A power supply. I've used my Quilter's 24V 3A supply (reads exactly 24V output) as well as the Amazon supply (output measures 24.4V).
3) I replaced the standard 1/4" input jack of the cabinet with a shunted jack. Unplugged, the amp is directly connected to the speaker. When another amp is plugged in, the 3118 amp is disconnected automatically.
4) Hammond enclosure is 1590WXXFLBK
5) I wanted a discrete install but able to access the switches/knob easily from the front (power and standby switches are same placement and distance apart as my Bad Cat). Because the input jack is vertical, I used a PureTone jack for the extra grip/security.
Great little build that's lived up to the hype. I'm building one to install in my Suhr Bella cabinet, as well. About to build an adapter to be able to use standard center-negative 9V power supplies like the Quilter can do (for lower wattage output, of course).
As you noticed, supply voltages do not match, *at all*.While a "pedal amp" might be a great use for this small board, what about a variable power converter to use this to replace a dead output amp in a classic early Solid State head. Almost all of the early Solid State amps such as Silverstone, Thomas Vox (Vox USA), Gibson, not to mention high-fi amps from the same era, have a transformer driver and a "totem pole" stack of output transistors. If the driver transformer goes bad, no one, NO ONE, makes replacements.
I have used other class D boards to rebuild early VOX SS amps. The voltage levels work since most are single +VDC. I have replaced the power transformer with one with a current level but same output voltage.
So an interface board to bypass the "dead" early output amp would make this type of replacement fairly easy.
Michael
Congratulations on your build
I always add a 5A diode inside my amps to drop a volt and have used at least 5 different cheap 24V 2A or 3A supplies from amazon that have all been fine. That said, you must be careful with ground loops. On my real pedal board for gigs, I have a cioks DC7 and it's aux 24V output is perfect for these. If you use a separate supply, you must have exactly one earth ground path from any/all the power supplies to the board.I have to buy a TPA3118 (the first one was a fake and I didn't try it!) but I still have any power supply 19/24v, and I don't know if or what I have to buy. I afraid about noise, of course.
And verify the earth ground pin on the mains is connected to the negative of the output voltage.My 1-Spot has an Italian plug without the central pin, so no earth ground. I see a lot of PSU 24v with Italian plug with no earth ground.
But I could prefer a PSU with German plug, pretty common in Italy, that has the two lateral "tabs" that do the earth ground.
Am I right?
My pedal power supply 1-Spot doesn't have the earth ground, so for the TPA3118 I need a PSU with earth ground, but I can't go over this, the cheaper PSU 24v I can find on Amazon (Italy) have Italian plug with no ground, or Schuko plug with no clue about ground connection. Perhaps more of them have no ground.I use 1N5408 soldered directly to the power jack in the amp. You can get 24V power supplies with or without an earth ground. If your power supply for the other pedals has an earth ground that is tied to the negative rail, then get a 24V supply that only uses a 2-prong plug, no earth ground. The point is it only have a single earth ground connected to the negative line of the guitar signal at your pedal board.
If there is no buzz or hum, then it's OK but really should have one solid connection to earth ground for safety since your guitar strings are connected to the negative of the power supplies. If either of those supplies goes bad and allows mains onto the output, would really rather have a fuse blow than you blow.My pedal power supply 1-Spot doesn't have the earth ground, so for the TPA3118 I need a PSU with earth ground, but I can't go over this, the cheaper PSU 24v I can find on Amazon (Italy) have Italian plug with no ground, or Schuko plug with no clue about ground connection. Perhaps more of them have no ground.
