That’s what I’m seeing everywhere is 4x7mm. These I have are 3x5mm and fit where the normal ones I find won’t.
Ended up buying one of those kits. Legit.Maybe SuperCyberCow will come to your rescue?
Many of us have been there. PCB is freshly populated, tested and working great. Now it's time to stuff all that goodness into a prepped enclosure. The drill holes have all been made and pre-fit tested for proper alignment and the guts go in nicely and even the jacks are spot-on with no interferences. Great! But then you go to screw that bottom plate on, only to find a few of the caps are too tall for the bottom plate to rest flat for closure.
Sometimes we can go back in and lay some of those tall caps on their side, or perhaps there is room on the solder-side of the PCB the jockey those...
- Cybercow
- Forum: Modifications
Sometimes when I need a small one, I take an SMD cap, bend out the bottom legs and remove the plastic base.
They are 3x5mm nichicons. Those 4x5 are the smallest I’ve seen so far besides the ones I have.Are they 3x5mm or 4x5mm? These are the ones I tend to get:
KF105M050C05RR0VH2FP0 | Chengx | Price | In Stock | LCSC Electronics
KF105M050C05RR0VH2FP0 by Chengx - In-stock components at LCSC. Price from $0.0069. Free access KF105M050C05RR0VH2FP0 datasheet, Package, pinout diagrams, and BOM tools.www.lcsc.com
Mine are Nichicons.Any manufacturer's marks on these?
Unfortunately, the 1µF SMD electrolytic caps are too small.Maybe SuperCyberCow will come to your rescue?
- Cybercow
I think this is probably the way to go. I should have bought 3-400 of the ones I have instead of 100. They were way cheaper than tants.You could use tants when you need a small 1µF cap.
