Ginsly
I've had pretty good results hand-drilling with a unibit, but even when I center punch and drill a small pilot hole things can drift a bit. I figure that can happen with a drill press too. Still, this is not sustainable!
Assuming I'll benefit greatly from doing things this way rather than awkwardly holding enclosures off the side of a shitty side table - what am I looking for, in your experience? I need something relatively inexpensive, not insanely loud, and as small as possible. Given that criteria, what would you get?
- This Vevor seems ok, and I like the fact that it has a simple crank for raising/lowering the height. That seems very important, and most of the lower-tier ones have a more awkward mechanism for adjustments.
- Not sure how this 4208T WEN and this 4206T WEN differ... Besides, they may be a pain to raise and lower. Still, seems well-liked. I've seen these on quite a few benches.
- Reading other drill press threads, seems like some people use a vise like this, some spring for a cross slide, and some seem to find that lowering the bit into a pilot hole eliminates the need for a vise.
- Assuming I need a vise, is it crucial that it's magnetic?
I'd love some input! I'm sure there are other factors I haven't considered.
