Veroboard - Is it worth it? Where is a good place to get some?
BuddytheReow
Moderator
Hey all,
I've built a few pedals now and am getting curious about veroboard and building from scratch. Is it worth it? Also, where is a good place to get some? Amazon?
I still do some building on vero on occasion and like it for certain things. I get mine from Tayda whenever I put in a parts order.
I've bought veroboard from both amazon and tayda. The one from amazon (BusBoard brand) was thick and substantial, whereas the tadya ones are thinner (not to mention much cheaper). I actually find the cheap ones easier to work with, but I haven't had issues with either of them--if you order on amazon read the reviews, I did see some that were not well reviewed.
I like veroboard for small circuits, and ones without a lot of knobs (like boosters and fuzzes). As the complexity goes up they can be more frustrating. If you're a sloppy solderer like me, solder can run down the lines, cross the lines, etc. I've spent more time debugging issues on vero than on pcbs. But I've also built several good pedals with vero, and it's rewarding (I have only one that didn't work out).
You should definitely try it see if you like it.
Vero board builds are fun and for the most part pretty easy—similarly to you I'm quite new to it all, but the jump into vero stuff was fairly low impact. I started with just about the simplest circuit I could find - the catalinbread naga viper.
If you're just getting started I'd stick to the main sites with a decent community of folks building and verifying the layouts. Whenever an interesting circuit gets traced and propagates through the forums, there's usually a few vero layouts to choose from within a day or two:
Vero is great for straightforward OD/distortion/boost circuits, or for mix and matching bits and pieces together in a single box. PCBs are generally the single largest cost in a DIY build tbqh, so it's a nice way to cut down the price on things you're curious about but not 100% sold on boxing up or whatever. There are also a lot of cool non-guitar-pedal stripboard layouts floating around on sites like muffwiggler for things like drone synths, filters, noise boxes, etc, etc, as well as a bunch of small utility circuits or daughterboards that you can add to other designs. Want to add a blend knob or an active EQ section or BMP tone knob to something else? You can build it up on vero and hack it into something else pretty easily.
I've not had any problems with strips lifting off of the tayda stripboard, and it's more substantial than the stuff I can get at the local electronics place here.
I guess my only advice would be that if you're consistently having issues getting pedalpcb or other PCB-based builds to fire up properly on the first go, I'd probably avoid doing stripboard for the moment as it just adds one more element of complication. It's not a particularly big one, but still, why make things more difficult than they need to be y'know?
Oh and yes - the point about anything that needs more than 3 or 4 knobs/switches being a hassle is very true. You run out of a space for wires in a 1590BB a lot faster than you'd think.
I’ve done plenty of vero builds, I started with them first. Helped me improve my soldering skills. I get mine from Tayda, never had any issues. It’s also less expensive than buying pcb’s. I do prefer pcb’s these days because it just makes for a cleaner build, less wire, and the pots provide a means of mounting the board. I never liked just having my veroboard floating around in the enclosure.
I wouldn’t shy away from a vero build if I couldn’t get a pcb for a certain pedal though.
I really like working with vero, populating a printed board is fun but it's so satisfying to build something from a completely blank canvas.
It's definitely a bit trickier and requires a bit more planning and concentration, but absolutely worth it. And it's cheap! If you mess up you can always start again.
Total noob here.
I ordered some pref boards from Amazon.
Thought I would practice making the SOB pedal on perf since my first attempt on a PCB was a fail. Spent a few hours hand re-drawing out the schematic of the SOB, it has definitely shown how convenient printed PcBs are, and the amount of work the PCB makers must put in. I’ve got two nights into this so far and am a bout 50% done. The back side is going to be a jumper jungle nightmare for sure... great for learning though.
vero can give you neater layouts but parts placement can be confusing when you try to compare a vero build to a schematic. good building and troubleshooting experience either way.
Total noob here.
Kicad and Eagle are free software that makes laying out circuits and PCB’s easier, DIY Layout Creator is great for laying out perf and vero boards. Use Kicad or Eagle to draw up schematic then lay it out, if working with perf the layout creator software is easy to use but no schematic, so draw it up in Kicad and then layout
Sweet. I will check those out tonight. Other good news. SOB boards are back in stock.
Ya I built a few pcb's here, then with the spare parts I had, I browsed Tagboardeffects until I found a vero layout with most the components. Just finished my first one and it kinda felt like making a free pedal. Two things I learned from it as a noob:
1. Watch a couple YouTube videos on cuts/links. I thought I knew what I was doing (famous last words) and did mine 100% opposite mirror image, but I still made it work.
2. Wiring. Way more wiring.
Other than that it's easy after your first one and I'll do more, but it makes you see the value of having a nice pcb made for you.
I enjoy the occasional vero building and it is pretty satisfying and also therapeutic. (if it works when finishing it that is ?)
Lots of tutorials on the net like on sites mentioned above.
I started simple too: orman mosfet boost, fuzzes etc, and since have build tubescreamers, a bigfoot magnavibe, a Danelectro autowah, and greer lightspeeds for example.
Really learns you what makes pedals tick and what components do and how to troubleshoot when something isn't doing what it should.
That said: I build my first Pedalpcb and I found it to be much easier and less time consuming building on a solder ready pcb.
Especially the wiring, like mentioned above is so much neater as that with vero/perfboard builds.
One other thing that I think is really satisfying about vero builds is the ability to do multiples and see if you can make a couple of the same thing sound the same as one another.
When the EQD black ash was traced a few months ago, I built one based on a vero layout and really loved the way it sounded. If you're like me (and I assume most of us) and order 50 resistors from tayda when you need 2, you can basically build five pedals for the cost of the switches/enclosures. So I built 5 more of the same pedal, gain matched transistors into sets, and made some quarantine gifts for a couple of pals. It was a nice way to spend some time over a few weeks and the repetitive element was nice and meditative.
And as someone else mentioned above, if something goes completely sideways the total cost of the parts you're tossing in the garbage is like $2, versus the stress of trying to salvage a $12 PCB that isn't working.
Anyway, I built up the Dinosaural Tube Bender with the Aion 'wyvern' mods last night and it sounds *fantastic*. Highly suggest checking this one out if you're interested.
The mirror imaging thing bit me too. I realized all the pins of an IC were inverted. Had to bend all the legs 180 degrees to make it work... the first IC lost a leg doing this, and the second try I did carefully and got it to fit.
