Aries Delta - Double Muffin Fuzz - Triangle and SUF 75.
What did you use for a guide to the parts since the build doc has been "coming soon" for long time. Some have recommended the Muffin Fuzz build doc but it's not an exact match.
I used the Muffin Fuzz build doc, the components do match up, you just have to make sure to not mix up the A and B variants. The components you are most likely are not able to match are most likely R23 and R24. those most likely are part of the tone bypass on the Muffin Fuzz. All the rest should match up perfectly.
Just so I'm clear, the tone bypass becomes a switch between the 2 type of Muff, correct? And, are the tone switch bypass modifications (R24 and C15) no longer applicable? It looks like those 2 parts are no longer on the board.
