How do you populate your pcbs. I know shortest parts come first but I’m asking do you fold both legs over to hold them in place and solder, populate and snip the legs then solder using putty or something to hold them in place? Some other way? I ask because I’ve been using the folded legs method and have a really tough time getting something out once it’s been soldered.
Folding legs is a no go for me. This is not how I learned it at school.
Well how did they teach you at school lol?
The thaught me how to draw a pcb on see through paper with rub-on soldering islands and 0,5 pentelpens. And then the proces of lighting. Acid. Drilling. And then soldering with no folds. Just straight legs and creating shiny joints.
And then I never touched a soldering station again until recently.
Ok, here’s one I’ve been kind of afraid to ask…
When I’m breadboarding, and I try to make a transistor-based circuit, it fails just about every time. By that I mean the audio signal passes through with little change, or it sounds weak. I do your typical troubleshooting, like check the pinouts, 2x check the schematic... I feel like I’m missing a detail from breadboarding 101 or something.
I don’t have this problem when breadboarding IC-based circuits.
There are transistor-based circuits that I would like to tweak and modify- it would be way easier if I figure this out!
Maybe post a pic or something
What size and shape tip do you use and at what temp?
TBH , it took some trial and error for me, and how my soldering is with my all thumbs hands sometimes.
I personally find the chisel 1.6–2mm a nice sweet spot.
Temperature: as long as it's a quality/accurate station, go with what the specs of the solder say it should be. The brand and formulation of 37/63 that I've been using says 365°C, so that's what the iron gets set to, and it's working really well.
I've got a Hakko, so I don't worry about the temp, it is what it shows.
