Recommend Me a Clean PreAmp
I have never heard anyone say this before.
I'm simply not ready for a tube project, especially since I've never played through a tube amp before. As reference I am primarily a bass player so guitar is a distant secondary, I just want to build a small board that I can plug into my bass head's power amp without needing my HX Stomp to play.
Tube preamp into a power amp is a pretty common use case for my pedals. Just saying.
I'm obviously biased here as I make money from selling these things, but hearing someone say they don't want a tube preamp makes me sad.
Fahrt jokess?
We don' wahnt noh Steenking fahrt jokess 'round here, we don't neeed noh steenking fahrt jokesss ...
... oh, wait...
... pull my finger... 👉
I was wondering why you don't just add a quality EQ pedal to the end of your PB chain, put that into a Class D power amp?
I'd personally go with a splitter (to front of house and that EQ pedal), into a used EHX 44 Magnum, Duncan Power Stage or a QSC GX3, into a used passive full-range PA speaker (12" w/ horn). Maybe skip the separate amp and speaker and find a used powered PA speaker.
I already plan to play through my 4x10 bass cab using the power section of my bass amp, so I have no need to buy an FRFR speaker or a separate power amp, especially since I'm not playing guitar on stage.
The pedal I posted above works great in situations like yours, for both guitar and bass. There are details in the build threads, or here: https://github.com/Passinwind/PW3B-LPF
If hand soldering SMD parts is too much hassle there's another through-hole version in the works, but it's down my work queue a bit for now.
Hell yeah, I'll take a look man. SMD is a PITA but it is something I can do.
I spec'ed relatively large SMDs (1206 resistors, SO-8 opamps) and all the caps are through-hole. There's a new version in the works that runs internally at +/-15V and can directly drive any power amp, but the current version already has plenty of headroom, especially if you run it at 12-18 volts.
