YesJust an example. When wiring up stripboard, the wires all get soldered to the ends of the board? So the wire for "Switch A1" gets soldered to the "A1" position?
Post a troubleshooting thread, and folks here can help sort 'em out.I've tried stripboard twice, both times produced no sound, bummer. I did two really simple fuzz circuits, still failed.
Ships from Germany: https://www.musikding.de/PDV-P9203Madbean's Phasor II asks for 9203 LDRs and Stompboxparts won't ship these to Europe. Those who want to help and have an order pending, hit the envelope!![]()
I can never unsee that.Every time I see that damn monkey, it's too small to see it's covering its eyes with its hands.
When at normal size...
... it just looks like it's pulled down its britches and bent over MOONING you.
First thing that comes to mind is ducking.Can somebody explain sidechaining to me? What are some practical applications of sidechaining?
Isn’t this pretty much the same as running a parallel blender? I use one of those Sonicake Portals, before owned an OBNE Signal Blender, to mix my wet delays or whatever in. The Portal can be set to run in series or parallel.I like my autowah after dirt, but dirt compressing the signal makes the autowah less quacky — so taking Robert's handy three-way splitter, I have:
DRY — route the signal through whatever order of pedals...
SIDE-CHAIN TO AUTOWAH (can put Envelope Filter anywhere I want)...
SIDE-CHAIN TO COMPRESSOR (can put compressor wherever I want and it reacts to dry signal off my bass/guitar).
SYNTH pedals should ALL have a side-chain, IMO, 'cause they track better with a raw signal, but maybe you need it after your fussy little don't-put-no-buffer-before-me Fuzz Face...
Side-chaining is when a signal output controls a parameter of another effect. So in Feral's example the autowah and compressor would have to have a separate input for the sidechain trigger that routes to one of those particular parameters, which in the case of the autowah would be the split dry signal routed directly to the envelope follower part of the autowahIsn’t this pretty much the same as running a parallel blender? I use one of those Sonicake Portals, before owned an OBNE Signal Blender, to mix my wet delays or whatever in. The Portal can be set to run in series or parallel.
N usually indicates MN. Tayda and amplified parts carry them iirc.MN pots?
I don't trust guys named JoJo.N usually indicates MN. Tayda and amplified parts carry them iirc.
On mouser they're categorized as "balance" pots
Braighlynn, Kayleigh, Tymon, Breehannagh, TragedeighI don't trust guys named JoJo.
Nor Aiden, Kaden, Jaden or Jaxon.
