Phase II issues
Ale_jellybelly
1. The yellow led doesn't light up in a smooth sine wave but the rise time is very fast, I can only control the fall time with the pots and trims
2. The led stalls when the rate is very slow, it stays on
What could it be?
Pics (I know, I need to remove some flux)
PXL_20260726_173833295.jpg PXL_20260726_173936928.jpg PXL_20260726_173949189.jpg PXL_20260726_173957201.jpg
What could it be?
View attachment 121552View attachment 121553View attachment 121554View attachment 121555
Looking at your pictures, could it be some solder residues shorting a soldering pad with another pad or with a nearby pcb trace ?
You can try to clean the board by vigorously brushing the pcb's soldering side with a dry toothbrush until you cleared most of of the soldering residues.
You can also clean the little spaces between pads, using the tip of your soldering iron. Move quickly to avoid overheating the pcb.
The best for residues would be some pcb cleaner spray, i use something with a brush on the tip and it's very effective to clean pcbs. To be used outside the house and maybe with a protection mask on, because it's full of chemicals.
in red, some solder residue examples.
In blue, a possible short.
The right pad looks like there's a bit too much solder and it could be touching the next pad on the left.
Thanks for taking a look
What might seem solder residue is actually just dried flux
I just gave the board a good scrub with some contact cleaner, and checked the point in the blue circle, no contact there
I found a thread blaming the LFO opamp for the wave shape(https://forum.pedalpcb.com/threads/phase-ii-lfo-wave-shape.25165/ ) . I'll try swapping it as soon as the board is dry
Measurements taken with DEPTH at max and RATE, FEEDBACK and trimmers around halfway
IC1:
1: 0
2: 0
3: 0
4: -8,74
5: 0
6: 0
7: 0
8: 9,19
IC2:
1: 0
2: 0
3: 0
4: -8,74
5: 0
6: 0
7: 0
8: 9,19
IC3:
1: 0
2: 0
3: 0
4: -8,74
5: 0
6: 0
7: 0
8: 9,19
IC4:
1: 0
2: 0
3: 0
4: -8,74
5: 0
6: 0
7: 0
8: 9,19
IC5:
1: fluctuates between 2-ish and 8-ish
2: fluctuates between 0 and 0.5
3: fluctuates between 0 and 0.5
4: -8,74
5: 0
6: 0
7: 0
8: 9,19
IC6:
1: stays around 8-ish, then dips briefly between 2 and 3, then goes up again
3: fluctuates between 5,9 and -1,5
4: -8,74
5: 0
6: 0,72
7: fluctuates between 4,5 and -4,5
8: 8,55
IC7:
1: 9,19
2: 5,28
3: 0
4: -3,68
5: -8,74
6: 4,23
7: 5,69
8: 9,19
