Looking at your pictures, could it be some solder residues shorting a soldering pad with another pad or with a nearby pcb trace ?1. The yellow led doesn't light up in a smooth sine wave but the rise time is very fast, I can only control the fall time with the pots and trims
2. The led stalls when the rate is very slow, it stays on
What could it be?
Pics (I know, I need to remove some flux)
View attachment 121552View attachment 121553View attachment 121554View attachment 121555
Thanks for taking a lookLooking at your pictures, could it be some solder residues shorting a soldering pad with another pad or with a nearby pcb trace ?
You can try to clean the board by vigorously brushing the pcb's soldering side with a dry toothbrush until you cleared most of of the soldering residues.
You can also clean the little spaces between pads, using the tip of your soldering iron. Move quickly to avoid overheating the pcb.
The best for residues would be some pcb cleaner spray, i use something with a brush on the tip and it's very effective to clean pcbs. To be used outside the house and maybe with a protection mask on, because it's full of chemicals.
in red, some solder residue examples.
In blue, a possible short.
The right pad looks like there's a bit too much solder and it could be touching the next pad on the left.
Great catchDouble check the orientation of c18.
Doesn't match the website image, but those aren't always a perfect match for the final pcbs.
yeahHave a DMM?
same thing on mine.2. The led stalls when the rate is very slow, it stays on
i get approximately the same readings on my build at IC1 TL72. I just have a steady -7.98V at pin4, with 9.1V at pin8 and 9.42V at the DC jack, but i guess that's probably nothing.IC1:
1: 0
2: 0
3: 0
4: -8,74
5: 0
6: 0
7: 0
8: 9,19
Phasing is there so the effect is workingsame thing on mine.
Same readings at IC7 TC1044 and at IC6 too except pin3 and pin7 are fluctuating with similar values from +4 to -4V i'd say.
I didnt check all ICs, it looks like yours are fine. I can check somewhere else if needed.
Only difference is that my led is lighting up more smoothly than yours.
Have you tried with another led ?
Do you have a phasing effect on the signal ?
