Tidy Build !Finally have time to start working on some pedals. Here’s another Brown Betty. I got one hole off just a hair![]()
Yep. It’s not nearly as close on those left two as it appears. The gut shot shows that better. I wasn’t straight up from the pedal when I snapped the pic. I’ve done a little filing as well. It’s always the spacing I have trouble with. The drill press fence is helpful to keep them in a line though.Tidy Build !
Just a hair, If your OCD gets the better of you you can just use a round file on one side of the Hole & square it up!
Dont go to the extreme where the washer doesn't cover the hole.
I can guarentee it has been done heaps here before in secret!!!
	Yes, They are a handy tool but what if the hole is 2mm to the left of where it should be!Evening gloves and gown on Miss Boop, very classy!
Instead of a rat-tail file, I use a reamer — knob's big enough to cover the faux-pas hole. Something like this:
