Nice!!!Oh wow I love the sound of this one! I built it to 70s gray box specifications with the help of Mr. PedalPCB.
Thanks!!!Thanks folks! Here are the gray spec subs from Mr. PedalPCB.
Add 25pF cap across R2
R3 47K
R5 470K
R6 20K
R7 20K
C1 2n2
C4 22u (positive lead in left pad)
C5 2n2
C6 10u
D1 1N4148
D2 1N4148
Gain C500K
Volume A10K *I used an A100k here*
Thanks! You'll be fine. Thats a 22uF in the 1uF silkscreen spot, as the mod suggests. I just followed PedalPCB's list to turn it into gray DOD specs. Following the build docs I believe it's closer to a Distortion+.Nice! A good example for a beginner like me to reference. I'm actually doing this build right now but according to the build docs. I'll have to try this variation on a later build. I noticed you used a 1uF electrolytic. Is that for this variation that you did on this build? I used a 1uF poly film box in that spot. Will that work or did I make a mistake?
Someone else with more electronics knowledge will have to chime in here. I just added the a100k because that's what all the gray spec mods I found on the interwebs suggested and what was posted above from Mr PedalPCB was very similar to everything I found (minus the a10k) so I went with it. It works perfectly and sounds great.Can you swap out the A10k to A100k to add more volume on the reg 250/distortion with out the other mods ?
Mike
Nice link. Though those are all dual op amps and I'm pretty sure it won't work in the 250 because it needs a single op amp.
IC op-amps characteristics
So since there are so many op-amps (dual, low noise) that you can try in the IC socket of your favorite OD pedal, I decided to write down how I would describe their characteristics so you can decid…vanespedalsandpickups.wordpress.com
I found this in searches, my thought it may come in handy , ill swap out a few IC's
People like running a 10 band EQ after the 250 Dist + like Randy Rhoads did...ill try a clean boost as well
741 Pin Compatible Equivalent Op Amps
Photos of 741 Pin Compatible Equivalent Op Amps, set against the Ca3140_compatible, 2x, Lf351n_compatible, Lm741_compatible, Mc33171n, Mcp601, Mcp603, Opa602, Tl061cp_compatible, Tl071cp_compatible, Tl081cn_compatible, Tl0xx, and Tlc271_compatible.www.petervis.com
