SYLV9ST9R
Nope, you only submit the COLOR layer thenI’ll take a look today.
Do I need anything in the white and gloss layers if I have no white and require no gloss?
That seems like a good template. Just be sure to remove all those in your final pdf, for good measure.I goofed around today and added a few utility layers:
1.) Tayda Drill Coordinates - Converts positions for use in Tayda Drill with measurements displayed
2.) PedalPCB Drill Template Positions - Plots out the positions from the drill templates with measurements displayed
3.) Pedal PCB Outline - Since the PedalPCB drill templates are measured to the outer rectangle that seems to correspond to the enclosure bottom, I included this
4.) Hardware - Overlays actual hole diameters, switches dimensions, switch nuts, pot dimensions, PCB dimensions and Knob dimensions. Helps plot out text and graphics
I can now keep master files in Corel draw that can toggle all the utility stuff on and off.
One thing i have not explore is getting the right color swatches should I ever need gloss and white. Right now those layers will stay empty as i can;t see myself needing them anytime soon.
Here is the swatches for Tayda's UV printing, not sure how you load them into CorelDraw (Google will be your friend)Anyone know where I can find a Roland Versaworks color pallets file to load into Corel Draw?
Yes it is!I was playing around tonight with Fuzz Face graphics and ill need a white layer on those. Is it absolutely necessary to use the Roland White color for Tayda printing?
Exactly.Quick question about using white: If I have a shape that will need to be printed in white on a black background, I need to copy that shape into the white layer in the exact position and then fill with RDG_White.
Yes, but be sure to remove it in your final pdf for printing.Can I also have that shape in the color layer in normal white so it shows in my mockups?
It shows up as a grayish hue.Understood.
Last question: I’m not crazy when I say RDG_White does not actually show itself anywhere as actual white, correct?
I wish there was a button like that to apply to my life.
I just sent Tayda a question asking if they print first or drill first when you order a pre-drilled enclosure with UV printing.
Did you vectorize an existing image or did you make the snake directly from vectors? It looks quite detailed.It can get pretty detailed. I think your design will come out nicely.
Pic looks grainy a bit because I played with it to show the design more, and it has matte gloss.
Pretty satisfied with the finished product. I had 4 enclosure and they all came out great (the other 3 were pretty simple designs), you'll see them later this fall![]()
I used the Image Trace function in Illustrator. You sometimes have to play with the advanced option, and do some cleanup, but I had good results with complex graphics.Did you vectorize an existing image or did you make the snake directly from vectors? It looks quite detailed.
Is there such a thing as a template with this borders/input-output indicators/negative pole info?
If I remember, someone did that in the big UV thread. I just vectorize my images by default, especially if I'm going to cut parts of it for superimposed text, holes, etc.Has anyone ever had a pedal printed without vectorizing the image first? If you place the image (created in photoshop with correct dimensions) and save your pdf in illustrator, Im wondering how it would turn out in the end![]()
It doesn't.. work. The printer requires vector instructions to actually print the lines properly. You can see examples of people forgetting to vectorise text etc, often it just doesn't come out at all.. other times it shows glitchy lines etc. But it never actually works. You must vectorise!Has anyone ever had a pedal printed without vectorizing the image first? If you place the image (created in photoshop with correct dimensions) and save your pdf in illustrator, Im wondering how it would turn out in the end![]()
