Travis Active member Dec 2, 2021 #1 Hi, could I add to DD-3T the hicut switch?? Wich cap is replaced by the switch? And also I wanna ask if anyone of you know If I can add the tap tempo like this photo
Travis Active member Dec 2, 2021 #2 I mean this mod and the tap https://www.doktorsewage.com/boss-dd-3-echo-echo-echo-mod/
Travis Active member Dec 3, 2021 #3 with this schematic could I get original sound when I use center "OFF" positions on the DPDT switchs? Thanks
Bricksnbeatles Member known well Dec 3, 2021 #4 To add the tap tempo, just wire one lug of the momentary switch to the tip connection of the tap tempo jack, and the other to the sleeve connection.
B benny_profane Well-known member Dec 3, 2021 #5 Bricksnbeatles said: To add the tap tempo, just wire one lug of the momentary switch to the tip connection of the tap tempo jack, and the other to the sleeve connection. Click to expand... Note that Boss typically requires a normally closed (NC) switch.
Travis Active member Dec 3, 2021 #6 benny_profane said: Note that Boss typically requires a normally closed (NC) switch. Click to expand... Yes thanks, I will use one SPST NC. Do you Know if I can choose the tempo with the external tap (or the new switch installed) and just turn on and off the effect with the original swith?
BlackMaple New member Mar 10, 2024 #7 Travis said: Hi, could I add to DD-3T the hicut switch?? Click to expand... Did you finally tried the mod on it?
