Hello everyone thank you for the help ahead of time. I recently built this paragon overdrive. When I had first plugged it in the left side would go in and out with audio if I moved it, so I took it out of the enclosure and the problem still continued. I also noticed that the right side would not produce any sound when engaged. Also when it was engaged it would cut out the sound that I was receiving from the left side but the sound would return when I put the right side back on bypass mode… help!
