pcb rookie
Fishing building the Super '64 OD. LED is working fine. I'm getting sound on by pass mode and clean low volume sound when engaged. All pots are turned fully clock wise including the trimpots. I looked at all solders for cold solders, bridge etc. Then cleaned the PCB. I refloweds all sorders, cleaned the PCB before inspecting again. I took some basic voltage mesures on IC, JFETs, Diodes and LED. Here are some pictures. Anything stands out in those values and pictures? This is my fourth built so I do not have much experience or knowledge. I will take all the help I can get! Thank you in advance for assisting with this troubleshoot.
Build docs: https://docs.pedalpcb.com/project/Super64.pdf
IC TL1044SCPA - data sheet: https://www.mouser.ca/datasheet/2/268/21348a-29235.pdf
Pin1: 9.09v
Pin2: 4.84v
Pin3: 0.1mV
Pin4: 131.5mV
Pin5: 0.337v
Pin6: 4.24v
Pin7: 5.61v
Pin8: 9.09v
J201's - data speet: https://www.mouser.ca/datasheet/2/308/1/MMBFJ202_D-2316065.pdf
Pin1/Pin2/Pin3
Q1- 7.71 / 0.39 / 0
Q2- 14.1 / 0.322 / 0
Q3 - 17.72 / 0.635 / 0
Diodes (1N5817) - A/K
D100 - 9.31/ 9.1
D101 - 9.1 / 13.73
D102 - 13.72 / 17.78
Pin1: 9.09v
Pin2: 4.84v
Pin3: 0.1mV
Pin4: 131.5mV
Pin5: 0.337v
Pin6: 4.24v
Pin7: 5.61v
Pin8: 9.09v
Pin1/Pin2/Pin3
Q1- 7.71 / 0.39 / 0
D100 - 9.31/ 9.1
D101 - 9.1 / 13.73
