What's on the workbench?
Well fuck me for buying the one spot device a couple years ago then
I have one of those too.
This is really no "better" than what you already have, in fact the module that is doing all the work is almost exactly the same.
This one is just slightly smaller and metal instead of plastic... It also doesn't have the built-in 1/4" cable tester like the OneSpot, which you may see as a positive or negative.... I found it useless so I won't miss it.
As soon as my enclosure arrives from Tayda I'll have a few available, then more in about two weeks.
I just need to make sure everything fits my template (or adjust the template) first.
I also have a bunch of the displays ready to go as well.
Love to grab one of these if they haven’t already been assigned.
Watt is currently on the workbench has me meter amped up.
Can it pull double-duty and work as a Battometer for instruments with onboard preamps?
