Looking back at it with fresh eyes this morning... 1mm too far apart. That one was drilled at 22mm distance and I already adjusted my drill template to 21mm but have not tested it yet... holes could be a little smaller if I was certain about the placement.
Anyway, here it is : https://drill.taydakits.com/box-designs/new?public_key=SXBFVGhsTUpSaFh6d1MzUjN1ZDNyUT09Cg==
I've DYI'ed a similar concept for a 125B type enclosure. 18vDC 1.5A input supply, a 9vDC (LM317T) regulator trimmed to 9v and filtered, (5) 9vDC isolated outputs and (2) 18vDC inputs.
If i can fit this with Terro board, PedalPCB can surely fit it with their double sided layiouts!
And that's fitted with the following, as suggested by M. PedalPCB himself, I may have added a washer so it's snug.
5mm Male standoff paired with a 20mm Female standoff
