C2C Electronics - Tayda Drill Templates
I guess the good news is a brand new printhead gives the crispest cleanest prints, so I have that to look forward to.
I was worried the Nobelium’s first run would run out before I could decide what else to pad my order with. Luckily, I managed to order a few enclosures and PCBs after agonising all evening and into the wee hours over what to get.
With all that I had, I was already at my $₶৲₱₽৲₦₲ & tax/duty-free limit, so thankfully the Supersonic was out of stock.
No Worries No Hurries here. I've got to pace myself a bit. I had a pretty good binge when you announced the C2CE site.
I need something to look forward to.
It's all about the antici...
images
Anymore drill templates ?
Mirage Tremolo will be the next PCB I want to order as soon as you get some more XLR DI daughter boards back in stock.
I always start my PCB designs with a grid with positions to place the pots and switches etc, that way all my stomp boxes and amps can use the same box as long as it fits in that size cabinet. I can hide unused holes with a skinny PCB fascia panel.
I'll get a Mirage template uploaded in the next day or two.
I want to get some artwork started and get a box ordered for the mirage. Do you have the template ready by chance?
Vigilante398, do you have a Tayda drill template for the Supersonic?
I think that one might be a bit hard to do by hand so I will have to get one made.
I might also make up a fascia PCB for it so I got one when I am ready to order the Supersonic PCB
I don't know how Tayda ships so cheap to Au but its great and fast.
I don't have a tayda template for supersonic because the 1590DD enclosures Tayda uses have walls too thick for the hardware to thread onto. Lovemyswitches is the only place I've found that has thin-walled 1590DD's that I can use with Supersonic.
So actually I guess I do have a tayda template for supersonic, that's how I know they're too thick, so I guess if you wanted to counterbore it yourself that's an option and I could share it.
Good to know that Taydas 1590DD is too thick walled, but the drill template would still be great to have in case I want to make a fascia PCB.
It would also be very useful so I can mark out the holes on whatever I will place it in, I prefer the dimensions like you have left at Tayda because I find it easy to align the holes with reference to the center of each face.
I am not sure when I will be buying the Supersonic yet as there are several others I am interested in, especially the Particle Accelerator since I could turn it into a Bassman 371, Dual Showman and the Alembic. ( Might have to make all 3 eventually)
Thank you
Michael
I have 2 routers I use for wood, I should be able to use a router on a stompbox to take a skim of the front thickness.
I am guessing it would be easiest to do it from the inside, I have to research if I need a special router bit first or if the wood ones will do.
I might have to make a jig to hold the stompbox still as well,
I really want to order some boxes with the slots milled out from Tayda but I keep hesitating.
How exactly do you order them and how do they know which box is for which drill template?
I want to order an Ambassador, Bassdude, Black Eye, Mirrage Tremolo, All 1590BB size.
I also would like to order a 1590BB2 with just the tube slots milled so I can try to fit in a 1W power amp with the OT transformer, slots for 2 tubes but nothing else.
Maybe also a 1590XX box for the Nobelium as well
Just wondering if you have had a chance to look for the Supersonic Tayda Drill Template yet ?
I would still like it just so I can make a fascia template for when I eventually make a Supersonic.
I will order one when you get some more PCB's in stock.
Thanks
Mick
Thanks
Mick
Best of luck to you, my dude. I'm not positive this has the FX loop jacks spaced the way they need to be, so keep that in mind and adjust as you see fit. This template is given without any guarantee.
Hey everyone, it's taken way longer than I expected to find time to put this together, but I've added a new page to the website for drill templates and some simple, ready-to-go, "stock" artwork files. I've also put together a walkthrough guide on how to place an order with the Tayda enclosure service for those that are new to the process.
I'm going to try to get the shop back open at some point today.
The walkthrough was very easy to understand and the templates look good, I do have one little request though....
Would it be hard for you to make a template for the Ambassador and the Black Eye that has "For Bass" in the bottom right corner ?
I am making them with bass mods and normal so I would like to distinguish which is which when they are built.
I think just like C2CE Design is on the left make the For Bass on the right.
If it is a lot of work then I can always use a marker after but it would be neater if it was done right.
Cheers
Mick
Cheers
Mick
My intention was to create a single "stock" file for each, I don't really want to do multiple versions to address possible modifications.
