KreoPensas
Don't use a relay bypass then.
SOLVED
SOLVED
PCB design is not just to avoid having hundreds of wires connected by hand.Please elaborate. I am all ears.
You also have to take into account that a micro-controlled relay bypass actually means a huge increase in complexity.Microcode? Proprietary. Gone.
Mechanical 3PDT switches typically do the job well enough, this is fair. But mechanically speaking, they are *far* more complex than a simple momentary switch. A momentary switch will short a set of contacts via a simple up and down motion, aided by a spring. The plunger bridges two points. A switch doesn't get much simpler.
The 3PDT on the other hand? Its an fairly complex machine. Three independent poles, the common on each needs to switch between two points in a synchronous motion. They work *very* well, but mechanically speaking there's a lot more that can go wrong.
I'll grant that in the grand scheme of things, it probably doesn't make a whole lot of difference, especially if one uses cheap switches. But there are momentary switches out there that far exceed the 30k lifespan of the cheapies, too.
Build one with a lehle switch, and as long as your circuit is well designed you're about as close to fail-proof as is possible.
Also, comparing to a momentary SPST (such as typically used by relay or electrical bypass schemes), such as this Pro-Grade SPST Momentary, it says "50,000 mechanical cycles; 6,000 electrical cycles". Not sure what that means exactly... why would you use it only mechanically, but not electrically? And if the actual reliability is dominated by the lower 6k number, that's disturbingly low!
Though with a relay in the right place the audio path can be made shorter.The argument about complexity must be taken from both the electrical and the mechanical sides of the equation. Sure, a relay bypass involves more components, which leads to increased electrical complexity.
And bingo! That is why I like this forum. It can get a little testy from time to time but overall this place is a beacon for all other online forums. Nobody gives a shit.@aquataur
Just a friendly heads up: Forums are great places to talk about DIY, gear, technical stuff, etc.
You seem mildly confrontational. You are not going to find anyone here gung ho either way for relay vs. mechanical switching.
They both have thier applications and I don’t believe anyone here is going to make a hard argument against either of them.
Yet you seem to be coming in guns blazing like someone came to you with a contrarian POV.
It’s YOUR thread. You set the tone for how the dialogue will proceed. Everyone is going to follow suit based on that.
I don’t believe anyone here feels intensely either way.
And bingo! That is why I like this forum. It can get a little testy from time to time but overall this place is a beacon for all other online forums. Nobody gives a shit.Nah, it's calm, reasoned and friendly, with only the occasional outbreak of memes.
That was in large part my fault. It was one of the only times I ever posted anything like that, and it felt gross. This is basically the only place I interact with people on the internet (no social media)- I don’t want it tainted either.I was cussing people out over politics less than two weeks ago but I re-adjusted quickly. I mainly was mad that any of that stuff WAS creeping in here.
TGP mostly feels to me like facebook for people that complain about facebook. It seems like >60% of the threads there have nothing to do with music. I occasionally read a thread here or there, but I mostly hang out there to peruse the classifieds.TGP drives me batty!
There's a few folks around here who do "stacked PCB" builds, with a custom bypass board that mates to PCB-mounted input/output jacks. The actual effect circuit is directly below the bypass PCB. So in bypass mode, the effective wire length is roughly the width of the pedal.Though with a relay in the right place the audio path can be made shorter.
One of the oddest things about pedal design is running the signal the whole length of the pedal twice from the jacks to the footswitch
I am *still* learning to Not Engage.I float between a number of forums and you can spot someone pretty quickly who thinks this place is one of the others.
Not to say I am perfect either.
