Missing Build Docs / Schematics
Hi @Robert
Any chance we could get a schematic for the MicroXLR Output?
Same subject but different request: would love just a drill template for the MicroXLR. I’m never too worried about drilling Pots and what not and most of the time the dimensions are similar from pedal to pedal. This XLR gives me anxiety because of the two mounting screws and I’d like to modify some existing pedals so fubar’ing a perfectly good enclosure is another layer of anxiety.
Thanks!
Thanks!
Reference the device datasheet.
Believe me I tried. Im sure it's somewhere obvious.
Is there a schematic for the
Basic Relay DPDT switch? Non latching. Im soooo confused trying to figure this out.
Try this, double check it before drilling.
@benny_profane is correct though, the drill template could vary depending on the XLR jack used. The attached template is for the XLR jack from Tayda, if you use a different jack you'll need to adjust the coordinates according to the datasheet.
