I feel dumb. Can this HepCat’s power jack be swapped to a center neg 2.1?
KR Sound
Seems like I should know this. Is there anything making this circuit unable to swap the power jack?
Or would I have to swap some cap orientations as well?
Do you still want to be able load a battery in there after swapping the power jack?
Maybe, I’ll have to ask my friend. It should just be a matter of swapping out the jack and wiring it like normal. It’s been a long day and I’m overthinking this.
If the goal is just to simply replace the DC jack, then yes, you can just replace it directly with any typical three terminal DC jack.
The pedal is positive tip / positive ground though. I assume your friend uses a special power supply with this one?
Reckon you could get some good clear pics of both sides of the PCB in there? For you know... science... :ROFLMAO:
Jack polarity is independent of circuit polarity - you can wire up anything however you want to. Your circuit looks to be positive ground, and requires a center positive supply.
If you want to use a battery still, you'll require a 3 terminal jack. Just match the pinout to what you have now.
I understand the point would be to convert it to center negative so it does not need it's own power supply.
I will.
