Lytt Effects
Ok, so I built one of the 4 Tap DC Isolators with the intention of using it as an off-board power supply for my “amp” setup, which is a UAFX Dream and Ox Stomp off-board. When I built the 4 Tap, I made sure to get the highest mA output I could find at Mouser, which was 330 mA, for each output.
Dummy me, I didn’t check the mA requirement for the UAFX pedals, which naturally require more than 330 mA. According to UA, they need at least 400mA, and I did test the current draw on each of them, which ranged from 350-375 mA. Fair enough.
Then, I had the idea that I could just double up the current from the outputs since I really only need two, and I built up some current doubling cables to do so. To do this, I twisted together the + leads of the cables coming off two of the outputs, twisted together the - leads off of the same two outputs, and then soldered them to the single cable + and - leads that go to a single DC power jack. I believe this is the correct way to do this, but please correct me if I’m wrong.
I’m using a OneSpot 9v 1A supply to power the 4 Tap. Each output is working properly, and will power a normal drive pedal just fine. When I attempt to power the UAFX pedals, things get weird. When I power either UAFX pedal with just one output, the pedal will continuously power cycle. This makes sense, as it is just under the mA requirement for the pedal. When I double the current and use two outputs with the current doubling cable, it will power up, but will then power cycle every 30 seconds or so. If I plug in both the Dream and Ox using just the current doubling cables, the repeated power cycling occurs for both pedals.
What am I doing wrong? Is this unit not capable of this, and I’m just dumb and should stop trying? Did I build the cables incorrectly? Any help would be greatly appreciated, and I can take pictures if necessary, just let me know what you need.
