A B looper stomp board
jimilee
Does anyone make an AB looper stomp board? I'm going to try a "channel switcher" with a master bypass in a combo build.
Another option is to use two ppcb intelligent relay bypass boards. Connect the CTRL pads on two of them and use channel switching mode.
Channel Switching Mode​
Channel Switching Mode is designed for use in multi-in-one combination effects pedals. When Channel Switching Mode is enabled only one effect can be active at a time.
Pressing any footswitch automatically activates that effect and bypasses any other active effect on the same control bus. Pressing the active footswitch again bypasses the effect.
This is what's in my big triple Rat. Works wonderfully except I do get a pop when switching channels
I don't have any issues with the 4PDT loop (no master bypass) selector, though
I've also used a GuitarPCB 2KnobJob PCB for a 2-x-Loop swapper-operator...
HIJACK ALERT!
What I want is Intelligent Relay where ONE (1) STOMPER is used both for bypass, quick stomp, AND stomp-hold switches the channels...
Does the PPCB Intelligent Relay do that?
If YES, do I use one stomper, but two IRelay boards?
HIJACK ALERT!
Oh cool. I might have one laying around here somewhere.
