inspired by this thread, i've been designing a board that contains:
-in & out jacks
-DC jack
-relay switching
-LED
-power conditioning
-input buffer
-option between buffered or true bypass
-VREF -- which, since i'll have a spare op amp from the input buffer, may as well be buffered. TL072s are 18c each at JLCPCB.
i have a couple of questions:
1) is there any reason not to put a 9V regulator before the switching circuit if you want to still have the option of using an 18V supply? would it require any other accommodations?
2) i noticed that this circuit has a protection diode, a voltage divider, and what looks to me like a power conditioning capacitor. is that because it's expected to be attached directly to an unconditioned 9V supply? since i intend to have a protection diode, power conditioning and buffered VREF on the board, could i use those, or should there be separate ones for the switching and the effect itself?
3) for modulation effects, i like to have the LED be modulated by the LFO too. is that possible with this circuit?
thanks!
