Caldo71
I have a separate thread just started on my Angry Charles build trying to suss out one issue, but apart from that I had two general newb-ish questions for @PedalPCB on component choices:
- I own a "real" Angry Charlie, and I notice that while the PedalPCB Angry Charles spec's the 3mm red LEDs, my off-the-shelf Angry Charlie uses the bigger 5mm ones. Why the decision to use the smaller ones, and/or does size even MATTER with LED clipping, or is the tone, breakup and resistance values the same regardless of which size one goes with?
- My ff-the-shelf Angry Charlie can use up to an 18v power supply for increased headroom—is the PedalPCB version similar enough in circuit that the sqme is true? Or will I "blow it up" if I try to use more than 9V?
