Any Tips For Building the Tyrian Distortion
dinkyguitar
Hi All,
I've built small circuits before including active guitar circuit from Projects for Guitarists by never a pedal.
So in building the above pedal, are there any tips?
Places to source parts? etc.?
dinky
At the top of this forum there’s a stickied thread “Basic Workflow Tips...” give that a good read.
Tayda electronics is a go to for a lot of people here. Lovemyswitches, DigiKey, Mouser, guitarpedalparts, pedalhacker electronics, uk-electronic, banzaimusic, musikding and there’s probably a lot more.
I buy potentiometers, resistors, film/ceramic/tantalum caps, non germanium diodes, basic transistors, toggle/footswitches from Tayda. I buy most everything else from DigiKey, uk-electronic and some sources I’d rather keep to myself :p (electro caps, wire, enclosures, jacks, tools, JFETs, anything germanium or obscure)
The most important thing specific to the Tyrian is the note in the build docs about installing the TL074 opamps.
They are a bit too close together to install them both flush against the PCB, there are a few ways to combat this.
The easiest method is to install the lower TL074 in a socket, but do not socket the upper TL074.
Aside from that, this is a fairly straightforward build with no "special" components. You can safely get everything you need from Tayda Electronics.
I see you've already discovered it, but there are a few good pics here:
Building any of the Revv pedals is jumping into the deep end. The Tyrian has a high parts count and very dense packing. Lots of opportunities for errors. I recommend starting with a simpler pedal. Scan thru the build reports for inspiration.
