Hmm - this does indeed look good for tricky situations. Minimum strip length of just under 4mm, looks like - that works. Some reviewers complain that the discarded insulation easily get stuck in the other side... Ever have that problem? Wow, that is one expensive wire stripper! Pretty cool, though.This one is also handy for some tight spots:
HF has gotten better over the years but still isn't up to the standards if many of the original tools they copy.
Ordered
i am pretty sure i had to buy a small set of jaws for it.
here you go. I looked in my history on Amazon. I bought them in 2017. That means I have been using these for 9 years. Worth every penny.Any chance you could dig up a link for those? Mine would get a lot more use if they'd do smaller gauges.
What would you say the minimum strip length is for that Katapult? It seems like many of these auto strippers may take off more than is needed for most pedal applications…here you go. I looked in my history on Amazon. I bought them in 2017. That means I have been using these for 9 years. Worth every penny.
Klein Tools 11074 Replacement Blades for Wire Stripper 16-26 AWG - Amazon.com
Klein Tools 11074 Replacement Blades for Wire Stripper 16-26 AWG - Amazon.comwww.amazon.com
Many, many thanks! That's going to open mine up to much more use.here you go. I looked in my history on Amazon. I bought them in 2017. That means I have been using these for 9 years. Worth every penny.
You can take off as little as you like, but you need to be able to feed in 1/2" or so of wire that won't get stripped... if that makes sense.What would you say the minimum strip length is for that Katapult? It seems like many of these auto strippers may take off more than is needed for most pedal applications…
Gotcha! Hmm this sounds pretty good, especially with those smaller jaws…You can take off as little as you like, but you need to be able to feed in 1/2" or so of wire that won't get stripped... if that makes sense.
I really do like the looks of that expensive, compact one but it does seem like it’d just constantly be jammed up…
Those plus these guys... I worked in datacomm / access control / nurse call industry for quite some time, and love me some snips.Hmm - this does indeed look good for tricky situations. Minimum strip length of just under 4mm, looks like - that works. Some reviewers complain that the discarded insulation easily get stuck in the other side... Ever have that problem? Wow, that is one expensive wire stripper! Pretty cool, though.
The first Knipex you posted looks pretty slick as well, but I feel like I'd constantly have to adjust that screw since I go between 22 and 24 awg. I guess that'd be the case with a lot of these, though. They're pretty close in gauge, so maybe one setting would work for both.
I use this Klein, and I'm pretty happy with it. I'd love something compact for tight spots, though... preferably not seventy dollars, good god!
I dig, and I wish I had those skills. Stripping quickly and accurately with shears takes a lot of reps before you get it right.Those plus these guys... I worked in datacomm / access control / nurse call industry for quite some time, and love me some snips.
Free-Fall Snip Stainless Steel - 2100-8 | Klein Tools
The Klein Tools 2100-8 Free-Fall Electrician Snips are crafted from stainless steel and feature wire stripping notches for 19 and 23 AWG wire, making them ideal for telecom, datacom, electrical, and heavy-duty applications. Their free-fall design, paired with an extended bottom handle, ensures...www.kleintools.com
I use the same Klein as @Ginsly for manual jobs, but as we all know I'm an obnoxious individual so I use one of these for most of my wiring because I know exactly what length I need and I know I need a couple hundred at a time.
Reasonably straight. The bit on the right side with the rollers is a straightener, if the wires don't go in straight they can miss the blade. You have to babysit it a little bit to make sure alignment doesn't slip while it's running, but it goes FAST so even with a realignment every 100 or so it saves a lot of time.That is sick. How straight do they come out?
