Hmm - this does indeed look good for tricky situations. Minimum strip length of just under 4mm, looks like - that works. Some reviewers complain that the discarded insulation easily get stuck in the other side... Ever have that problem? Wow, that is one expensive wire stripper! Pretty cool, though.This one is also handy for some tight spots:
HF has gotten better over the years but still isn't up to the standards if many of the original tools they copy.
Ordered
i am pretty sure i had to buy a small set of jaws for it.
here you go. I looked in my history on Amazon. I bought them in 2017. That means I have been using these for 9 years. Worth every penny.Any chance you could dig up a link for those? Mine would get a lot more use if they'd do smaller gauges.
What would you say the minimum strip length is for that Katapult? It seems like many of these auto strippers may take off more than is needed for most pedal applications…here you go. I looked in my history on Amazon. I bought them in 2017. That means I have been using these for 9 years. Worth every penny.
Many, many thanks! That's going to open mine up to much more use.here you go. I looked in my history on Amazon. I bought them in 2017. That means I have been using these for 9 years. Worth every penny.
You can take off as little as you like, but you need to be able to feed in 1/2" or so of wire that won't get stripped... if that makes sense.What would you say the minimum strip length is for that Katapult? It seems like many of these auto strippers may take off more than is needed for most pedal applications…
Gotcha! Hmm this sounds pretty good, especially with those smaller jaws…You can take off as little as you like, but you need to be able to feed in 1/2" or so of wire that won't get stripped... if that makes sense.
I really do like the looks of that expensive, compact one but it does seem like it’d just constantly be jammed up…
Those plus these guys... I worked in datacomm / access control / nurse call industry for quite some time, and love me some snips.Hmm - this does indeed look good for tricky situations. Minimum strip length of just under 4mm, looks like - that works. Some reviewers complain that the discarded insulation easily get stuck in the other side... Ever have that problem? Wow, that is one expensive wire stripper! Pretty cool, though.
The first Knipex you posted looks pretty slick as well, but I feel like I'd constantly have to adjust that screw since I go between 22 and 24 awg. I guess that'd be the case with a lot of these, though. They're pretty close in gauge, so maybe one setting would work for both.
I use this Klein, and I'm pretty happy with it. I'd love something compact for tight spots, though... preferably not seventy dollars, good god!
