Svenson007
Hey guys. I would like to use a pedal pcb buffered bypass daughter board I have with the awful waffle pcb…… since it’s true bypass and all. Can you please see my pic showing the breakout board next to the pcb? I have no idea what hole goes where….. There are extra holes on the breakout board so I can’t figure it out. I know the outside two don’t count as IN and out aren’t wired to the switch on this one. Any help would be great. I’m trying to get this puppy done ASAP. Cheers
Or is this just not comparable. Since the pcb isn’t marked it makes it hard. When I tested the circuit it seemed the second hole from left was ground
