Benson Preamp - Microphonic J201's?
BeeSharp
Hi,
I just built my second Benson Preamp and it has the same problem as the first. It has a noisy background (just high noise floor - nothing crazy). When I touch the Q2 J201 (which is a SMT mounted one from PedalPCB), you can clearly hear my touching it like a microphonic preamp tube. Any thoughts?
Thanks!
After fooling with it a bit more and reflowing some solder, the 100nF input cap and some others also seem microphonic. You can lightly flick them and here a thump thru the amp
What power supply are you using? I don’t think the components are microphonic, I think when you tap on them something that’s acting like an antenna is shaking and picking up different noise. The question is: where’s the antenna? Power supplies come to mind but other things may be doing the same. Is the circuit in the enclosure?
Hi,
Thanks!
Don't touch it? Ha ha ha. Probably a bad solder joint. Inspect everything under magnification. Some amount of noise is normal when you crank the gain. SMT transistors should not be microphonic. Ceramic caps can be.
And like Music6K said, pictures please.
I see what you did there with the two 1M resistors and the diode on the back side. Very clever solution!
Trimpots can be microphonic. You might try twisting them back & forth a few times, then reset them to their previous positions.
Are you sure you have clearance between the solder tits and the 1M dual pot?
Check the clearance between the bottom of that huge-ass filter cap and diode's solder tits. (yes, it's a legit term, I didn't make it up).
The solder joints on the middle JFET might be cold. You can tell better than we can. Doesn't look like the solder wetted to all three leads.
Thanks Chuck! I did see a little "tit" sticking up and potentially touching the dual gang pot. I plugged it back in, I can't remember if this happened before, but with the pedal back in the enclosure, when I touch the dual gang pot's shaft, I get a buzzy sound...The big electrolytic is not touching the 5817 diode tits. I reflowed the solder on the middle jfet
That hum problem is usually caused by the pot case not being properly grounded. Make sure the pots and jacks are all making metal-to-metal contact with the enclosure and the jacks are grounded to the board. The good news is that your case is bare metal inside, no paint scraping req'd.
I made sure all pots are grounded well and touching the enclosure, but it still has the same noise and microphonics that they other I built does. Here is a short video:
